Work Centre 7228 Bypass tray not working
  • glenng
    • 40
    Hi
    Had a massive jam in bypass tray, it fed several sheets of card at once. I removed tray and found cog mount plate had bent with the force.
    I straightened the plate and all cogs looked fine. Now when I print from bypass tray it makes all the right noises but the feed does not kick in and after a minute gives jam error. I'm not sure that the feed solenoid is activating.
    Solenoid tests OK in component control and all main drive cogs are running. I have also replaced the tray with another still no joy.
    Has anyone have a suggestion where to check next?
    cheers
    Glenn
