xerox DC 400 lines on copy problem
  • newtech
    • Mar 2009
    • 13
    Hi , I am making a one sided copy and i get a line on copy at the back ( not printed side) of the paper . It is a straight line across the short edge if the paper comes out long edge.
    I have tried the following so far .
    1. try to change the drum ( even though the line on the paper side does not touch the drum ) just trying.
    2. change the btr roller ( cause the line side is touching the BTR roller
    3. change the platen glass ccd
    4. clean mirror in the IIT -platen glass
    5. clean all roller.
    6. change fuser unit
    Note: Internal print shows no line on the other backside of the printed surface. only when from platen and dadf.
    Anybody experienced this tricky issue? Appreciate if somebody can share.
  • johnner66
    • Mar 2009
    • 265
    check the regi... btr gear then the hvt pwb how about print report any problem
    • newtech
      • Mar 2009
      • 13
      settle...thks
      ok thks I ve fixed the problem - adjust the lead edge settings.
