Hi legends. 1st post. here goes.
Have a FX 700 DCP with D3 finisher. Intermittent error 012-100 now constant error.
Machine passes paper without finisher attached.
Have replaced Decurler IF board, replaced D3 finisher main board, continuity tested connecting cables, decurler motor and clutch engage and turns in test mode,
Plugged and unplugged all board connectors multiple times, checked and tested decurler in and out sensors in i/o mode, all good , firmware updated machine to 1.130.9
Cleaned and tested exit sensor IOT.
Did see that gears meshing in decurler could be an issue all looks good.
Any advice greatly appreciated.
