Versant 80 Fiery P2X
  • big mike
    • Sep 2012
    • 155
    When loading software with a USB onto a bustled controller, you power it off (disconnect the n/w cables, hdmi), flip dip switch on, insert the usb, power it on, correct? When I tried it, it never loaded the software, came up with 00. Am I missing something, any ideas?
  • xcopytech
    • Aug 2006
    • 1794
    Re: Versant 80 Fiery P2X
    Yes, that is correct procedure.
    Check software on usb stick.
    • chubblies
      • Jun 2011
      • 155
      Why are you reloading? If it comes up 00 it should be fully working. You can reload via ethernet also, you just flip one of the dip switches and it issues an ip to your laptop to connect.
      • InterfaceP
        • Jun 2013
        • 488
        Make sure you're using the Fiery USB Prep Tool to load the software on the USB.
        • big mike
          • Sep 2012
          • 155
          I retried it and waited longer. It works like it should.
