Fault code 094-321 on DC250
  • jeanpaul
    • Mar 2009
    • 117
    I have a DC250 which display Fault code 094-321 & even I have change the Transfer Belt asssembly the 094-321 is still present.
    Any help is most welcome.
  • xcopytech
    • Aug 2006
    • 1792
    First BTR Contact Failure
    • johnner66
      • Mar 2009
      • 265
      try change the ibt assy to confirm wherther the clutch oh the assy itself problem
      • jeanpaul
        • Mar 2009
        • 117
        I change the ibt assy, but still 094-321 is display
        • TechMate
          • Mar 2008
          • 285
          Check contact points between retract sensor harness and the IBT main socket. It could also be an NVM corruption. Reset NVMs to default values. If the fault is still there, it must be either one of 2 components failing - the AC drive PWB or the MCU PWB
          • joluaz
            Re: Fault code 094-321 on DC250
            i wath is the soluttions??
