xerox altalink b8045 series toner chip solution need,
  • Tamal@1990
    • Jan 2024
    • 2
    [CQ] xerox altalink b8045 series toner chip solution need,
    hi
    how to disable toner chip in xerox altalink b8045 series.please help if any one have solution.
  • hnami
    service technician
    • Nov 2023
    • 171
    Re: xerox altalink b8045 series toner chip solution need,
    There is no code genetator for it yet
    • Tamal@1990
      • Jan 2024
      • 2
      sir any nvm value available??when install new chip it shows 10%.
      some time it shows improperly seated.
      • hnami
        service technician
        • Nov 2023
        • 171
        Hello
        The nvm value is given by default by the factory, also the nvm values are available in the box inside drawer number one
        Usually, the amount of chip depends on the use and does not depend on nvm
        • Sufyan Ali
          • Sep 2024
          • 2
          I Have A Solution for Xerox Altalink b8090 Chip Free. I got Almost 80% Solution, If There Any Program Master Then It Will Surely Work 100%. if anyone can help plz make a whatsapp+917772811010
          • hnami
            service technician
            • Nov 2023
            • 171
            Use this method:
            When the remaining toner indicator is not yet finished and for example shows 50%, remove the toner chip from the bottle. Then place the bottle and when you close the lid, you will be asked if you have replaced the toner or not. Choose the answer no. Then the device will not give you any warning until the toner runs out, and when the toner runs out, you fill the bottle with non-original toner and stick the chip on the bottle again, and when you close the front door, this time the question Answer with yes. The toner indicator shows 50% again. Take out the bottle and remove the chip and answer the question with no again. The device is ready.
            • Jeroen Steen
              • Sep 2024
              • 6
              Sufyan Ali Can you be a little bit more specific about the solution?
              • Sufyan Ali
                • Sep 2024
                • 2
                Whatsapp me sir +917772811010
