Xerox 700 127-212
+ More Options
Posts
  • Samxerox
    • Apr 2023
    • 44
    Xerox 700 127-212
    Hi All.
    All advice welcome.
    Im just after aquiring an other 700 printer.
    When I switch the bustled rip on it comes up on the engine as full functional but when I as the machine to print out a network report it gives me the error 127-212.
    So far I have taken yhe efi card out and put it back in along with ram and the hd connections.
    I also connected a monitor to the rip to see what would be displayed and it shows.
    Ok Booting the kernel
    Nothing more.
    Im guessing could the os be corrupt.
    If so where can I get the software disks since I do not have any and if they are expensive I will just keep the engine as a parts bin for my other one.
    Also is it possible to print direct to the engine useing a usb cable.
    Sam
  • xcopytech
    • Aug 2006
    • 1792
    Re: Xerox 700 127-212
    How you know that rip is fully functional?
    What you have on small led display on fiery?
    • Samxerox
      • Apr 2023
      • 44
      I believe the rip could be correpted and that the os is not operating correctly especially since I cant get it to connect to command work station either.
      The fiery displays I believe 00 on the led display.
      maby im missing something like a cable issue but since I cant get it to link to command work station Im thinking the operating system is not working correctly.
      • xcopytech
        • Aug 2006
        • 1792
        Reinstall fiery system software
        • adriansto
          • 2383
          Originally posted by Samxerox
          Hi All.
          All advice welcome.
          Sam
          No.
          • adriansto
            • 2383
            Hi All.
            All advice welcome.
            ................ it gives me the error 127-212.
            Sam
            Look:
            • Samxerox
              • Apr 2023
              • 44
              thanks for the input were could i get the install usb file for the server that is a mmx model.
              The previous owner didnt supply the required disks.
              • xcopytech
                • Aug 2006
                • 1792
                Mail me at xcopytech@gmail.com
