Xerox 700 045-310
  • Samxerox
    • Apr 2023
    • 44
    Xerox 700 045-310
    Hi
    I have a fiery that when connected is giving me the error 045-310
    I have another identical fiery that works with the enhine with no issues.
    What could the cause be because the fiery with the issue has an imposer and I do not know if its possible to activate the imposer on the good rip.
  • xcopytech
    • Aug 2006
    • 1792
    Re: Xerox 700 045-310
    Bustled or standalone fiery?
    What software version is installed?
    Do you have all patches installed?
    • Codex
      • May 2008
      • 694
      Try to invert the connectors... Had this issue twice... Once it was a dirty SCSI card, and the second time i swapled the connectors
      Inviato dal mio SM-S901B utilizzando Tapatalk
      Memento Audere Semper
      • Samxerox
        • Apr 2023
        • 44
        Its a standalone
        the rip is a TBA running on configure V2.1.46
        the engine is running 4.85
        as for patches I dont know because these are machines I bought resently and I dont know there history.
        • Samxerox
          • Apr 2023
          • 44
          Thanks for your input tried swapping the cables with no success.
          Im starting to believe the video card is dead or faulty.
          The machine starts to print and then just cuts out
          • adriansto
            • 2384
            Originally posted by Samxerox
            Its a standalone
            What others error is on machine faults history?
            Possible interface pwb from Fiery have problems.
            • Samxerox
              • Apr 2023
              • 44
              The engine is having no issues. I have another fiery tba and when I connect it to the engine it is printing no issue.
              The only reason I wish to use the fiery with issues is because it has imposer activated.
              Im thinking im having a video board issue.
              Is it possible to transfer the imposer dongle to the other fiery and activate it on it.
              • adriansto
                • 2384
                You must install Enfocus PitStop dvd software. Impose dongle kit = 133N23235.
                The impose works without dongle but there will be watermark on print.
                • Samxerox
                  • Apr 2023
                  • 44
                  you must install enfocus pitstop dvd software. Impose dongle kit = 133n23235.
                  i have the dongle but not the activation code lol
                  hence why i want to get the broke server working.
                  At this stage im fustrated so im going to give up for now.
                  • xcopytech
                    • Aug 2006
                    • 1792
                    Its a standalone
                    Can you print configuration page from fiery
                    • Samxerox
                      • Apr 2023
                      • 44
                      If your refering to from the engine side.
                      Yea I got it to do that if I remember correctly.
                      I have it disconnected at the moment from the printer but still connected to the system as to use the imposer.
                      I belive I got the fiery to process and print once a plain text document.
                      But every time I ask for a pdf file to be printed it process it no issue.
                      The engine starts and acts like everything is ok.
                      For it to suddenly stall and give the error.
                      As for its imposser its working fine but the pc I usually use its requesting activation while a different pc allows me to use imposer no issue on the broken fiery.
                      I think there a issue with the video card since the engine is printing with no issues connected to a different fiery.
                      • xcopytech
                        • Aug 2006
                        • 1792
                        What is software version on fiery. V1.0 or 1.5
                        • Samxerox
                          • Apr 2023
                          • 44
                          V1.5 if im reading it correctly
