Xerox Fiery Impose issues
  • Samxerox
    • Apr 2023
    • 44
    Hi
    Any information welcome on this.
    I have fierys running on windows 7 for versant 80s and xp for a 700.
    I have an imposer on a xp server and on windows 7 fiery.
    The first issue is I use a standard pc as a controller using camand workstation 5.8
    When I try to use the imposer it says its not installed.
    The second issue is if I use the iposer on the windows 7 fiery for the 700 machine it says that acrobat is not installed and wont display the file.
    Is this just a limitation of the systems or am I missing something.
    Regards
    Sam
  • Gaffers01
    • May 2011
    • 334
    Re: Xerox Fiery Impose issues
    Impose has a license, so maybe an issue with the licensing.
    • Detonation
      • Feb 2010
      • 406
      Yes likker Gaffers01 said, Impose is not a standard option, but you need to purchase a license.
      On the 700 Fiery: is Acrobat in fact installed? If not, you'll need to reinstall. Do you have the original software?
      • Saturn
        • Nov 2023
        • 171
        In the past, the Fiery software was often secured by a dongle, which you had to plug into an USB port of the computer on which the software is installed.
        I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
