Very Light Copies when using glass or dadf C8055
  • janik123
    • Feb 2024
    • 19
    Hello i am having an issue with copies they are very light, tried reset nvm, calibration, Led Lamp Change Main PWB, Scanner PWB, nothing helps. Can u guys help me out pls Is it LPH or what.
  • XEROX_1111_TEC
    • Aug 2019
    • 69
    Re: Very Light Copies when using glass or dadf C8055
    Can you share de repetitive defects sheets?
    If you scan it remains to light or is only with copies?
    • Gaffers01
      • May 2011
      • 333
      Try a double sided copy through the dadf to see if the second side is the same.
      What about scanning? does that look the same
      • XEROX_1111_TEC
        • Aug 2019
        • 69
        • hnami
          service technician
          • Nov 2023
          • 166
          1.make a scan in pc
          2.is the scan picture to light?
          3.if yes chek your mirore for dirt
          4.if no chek your toner first bad quality toner can make light images
          5.if no chek your developer tank & lph
          • dalewb74
            • Feb 2018
            • 1110
            im no xerox tech. but have you cleaned your optics? before replacing any parts.
            • janik123
              • Feb 2024
              • 19
              Hello guys thank you all for your help the solution was Dirty LPH lead print head, i cleaned it with glass mirror and the copies were much better readable.
