Xerox stock library manager problem
  • rowaner2002
    • May 2021
    • 6
  • xcopytech
    • Aug 2006
    • 1792
    Re: Xerox stock library manager problem
    1. Check crossover cable between fiery and machine.
    2. Reload fiery system software
    • adriansto
      • 2383
      Before this check the printer ip = 100.100.100.101 and Fiery ip = 100.100.100.102
      • rowaner2002
        • May 2021
        • 6
        • xcopytech
          • Aug 2006
          • 1792
          You must have crossover network cable between versant 3100 and fiery for stock library.
          Also as Adriansto said check that versant ip 100.100.100.101
          • adriansto
            • 2383
            Fiery communicate with V3100 using ethernet crossover cable for Stock library.
            On Fiery the top ethernet port is for connecting to your PC/network and the lower ethernet port is the place you connect the crossover cable. The other end of crossover cable goes to V3100.
            • rowaner2002
              • May 2021
              • 6
              • rowaner2002
                • May 2021
                • 6
                thank you I will check these out
                • adriansto
                  • 2383
                  It is ok. My mail = stoadis@gmail.com. Please post here in forum the Fiery's configuration pages or send it on my email address.
                  • Milo Wilson
                    • 499
                    What firmware level are you at on the 3100? What Fiery software version are you running and have you done Fiery patch updates?
