Xerox Phaser 7800 Green screen and reboot
  • copyTcat
    Senior Technician
    • Apr 2015
    • 58
    [Misc] Xerox Phaser 7800 Green screen and reboot
    We got a Xerox Phaser color 7800GX at client location that has green screen with xerox logo attempting to finish boot process and than machine reboot again and again. (Boot Loop)
    We suspect the SD card got issue but not sure. Is there a way to reload new data or image on the SD card or should we look into main board?
  • Dickie
    • Nov 2011
    • 190
    Re: Xerox Phaser 7800 Green screen and reboot
    Had a similar issue with a Xerox phaser a while ago, not a Xerox expert but as it boots it seems to run up different parts of the machine in a specific order, it got to a certain point and then dropped and rebooted as you described, turned out to be the power supply dropping out under load when a specific component kicked in. Removed P.S.U. and found visual signs of damage. New P.S.U. fixed it
    Good luck
    • Detonation
      • Feb 2010
      • 410
      You can reload the contents to the SD card with a disk image application. I have the SD image available.
      • hnami
        service technician
        • Nov 2023
        • 169
        Software damage.reload the software.boot loop It has nothing to do with SD
        • copyTcat
          Senior Technician
          • Apr 2015
          • 58
          hnami , to reload firmware again to the printer will help? but printer will not stay on ready to connect.
          • copyTcat
            Senior Technician
            • Apr 2015
            • 58
            Thank you all. Reloaded software and replaced hard drive just in case(was old) now printer work.
