Xerox v180 048-310 or 048-311 decurler cam position fault
  • sappster
    • Mar 2024
    • 7
    I'm experiencing a recurring fault for the decurler module cam shaft. I can power off the machine, manually adjust the cam position to 90 degrees clockwise from top dead center and power on. That it seems to temporarily resolve the fault, but it will return after a few hours of running. I suspect the cam position sensor is going out or maybe the motor. I'd like to track down a service manual to help debug (will post in the other forum). But any additional ideas?
