WC 6655i Scanner Fault
  • Hoosierdaddy
    • Oct 2016
    • 182
    It will not Pull paper thru the ADF Unit. Is this point at the ADF or Scanner? Thanks in advance I typically dont work on these. It also saysScan and Copy Services not Available
  • adriansto
    • 2392
    Re: WC 6655i Scanner Fault
    If it can copy from glass then problem is dadf unit.
    You must check error codes
