WC 7845 black print issue
  • Jack79
    • Jul 2014
    • 312
    Hi.
    I am looking for an advise regarding bk prints issue as per attached photo. Please look at the top (left side of photo) of the page there are a lot of short black lines - ignore white lines.
    Defect appear on black only. Colours are fine.
    I have narrowed problem to transfer belt assembly.
    Honestly seeing this defect my guess was 1st btr in itb assy. After swapping whole itb assy problem is solved however I would try to find and understand what may cause it .
    It is not machine related problem (tried the same itb assy on 2 machines and problem follows) but itb assy only.
    Itb assy has been cleaned.
    Bk 1st btr has been swapped with cyan - still problem with bk so deffect did not follow
    It belt sleeve has been swapped and still the same issue persist
    Can you advise what I overlooked and give me some suggestions please?
  • Murv
    Sr. Escalations Analyst
    • Mar 2021
    • 182
    Re: WC 7845 black print issue
    Originally posted by Jack79
    Hi.
    [ATTACH=CONFIG]62410[/ATTACH]
    Did you install new 1st BTR bushings and add some conductive grease to them?
    • adriansto
      • 2383
      Hi.
      Defect appear on
      There is bulletin for this defect = Rain Drops.
      • Jack79
        • Jul 2014
        • 312
        Hi I did not know about new bushing. What is the part number please?
        • Jack79
          • Jul 2014
          • 312
          Thanks for this.
          What is the bulletin number please?
          • adriansto
            • 2383
            Thanks for this.
            1393894, 1437179, 1413246
            • Jack79
              • Jul 2014
              • 312
              The first bulletin says exactly what I have done however I did not clean end pins but I swapped 1btr and this did not help.
              Unfortunately I do not have other 2 bulletins. Would you be able to share them?
              • adriansto
                • 2383
                Send me mail = stoadis@gmail.com
