WC 7220 problem with xerographic system
  • Doctor
    • Sep 2010
    • 133
    Good day all,
    I have a Xerox WC 7220 that shows adjustment in progress and ends with problem with xerographics system. It does not copy or print. Following errors are logged: 391.919.00, 918.00, 917.00, 914.00 and 393.929.00, 928.00, 927.00, 924.00.
    I have changed mcu pwb. Somebody pls help.
  • adriansto
    • 2387
    Re: WC 7220 problem with xerographic system
    Originally posted by Doctor
    Good day all,
    Check main drive assy gears.
    • Doctor
      • Sep 2010
      • 133
      Thanks for your response.
      I have changed the main motor drive assy. Same prbkem
      • Doctor
        • Sep 2010
        • 133
        Hello all,
        Just discovered the problem is from the yellow toner crum, I changed the yellow toner and the problem disappeared but the machine came up with error 361.320. I changed the ROS and 361.320 disappeared but the print quality is poor. The manual talked of doing GP8: Forced ADC Setup. GP 8 isn't in my manual. Don't know what to do next. See attached the print out of the grahics demo page.
        • adriansto
          • 2387
          Hello all,
          1. Open the Front Cover
          2. Switch off the Power Switch, then the Main Power Switch
          3. With the Front Cover still open, switch on the Main Power Switch then the Power Switch
          4. After the UI displays Close the Front Cover, close the Front Cover.
          5. The forced ADC Image Density Setup operates automatically.
