Print quality issue on DC5252
  • davidj7
    • 1107
    The trailing edge is blurred in coated 280 gsm paper on DC5252. I have attached a sample print.It happens only in 12.6*19.2 size paper printing in full bleed and on coated 280 gsm, does not happen on coated 220 gsm or less. machine has done 11,00,000 new 2nd btr.
    a machine is only as good as your tech : source:screwtape ; the scary one
  • Milo Wilson
    • 508
    Try this
    Modify NVM values of 2nd BTR transfer.
    151-220 gsm coated, change:
    746-856 nom.= 101,2nd BTR 151-220 Side 1 duplex, modify value to 80, or 70 (if needed)
    746-862 nom.= 97, 2nd BTR 151-220 Side 2 duplex, modify value to 80, or 70 (if needed)
    221-280 gsm coated, change:
    746-857 nom.= 87, 2nd BTR, modify value to 70 or lower if needed (never go below 55)
    • davidj7
      • 1107
      thanks milo , problem solved.the value was 78 i set it to 70
