Dcc 240
  • newtech
    • Mar 2009
    • 13
    Dcc 240
    Hi , my Dcc 240 toner reading indicated under the consumables stays at 100 percent even after I ve printed alot. I ve tried to flip the switch behind the toner but it still doesnt work. ANy tips?thks
  • copymachine
    • May 2009
    • 53
    Do you have any fault or CQ ? Can you describe problem of quality?
    • newtech
      • Mar 2009
      • 13
      reply
      Hi , there is no error message at all . use the toner a lot but the indicator remains 100 percent . my worry is when the toner finish it wont prompt me at all and just stop printing. Something is wrong with the toner level reader . But step by step what should i do? I have flip the metal switch at the back to the toner but still no changes.
      • davidj7
        • 1107
        i had a similar problem with 3535 I had to do a NVM initialize , NVM was corrupt.After reset everything went back to normal
        a machine is only as good as your tech : source:screwtape ; the scary one
        • newtech
          • Mar 2009
          • 13
          reply
          Hi all , what is the nvm initialize code for my copier model - dcc240 to try and fix this issue?
          • copymachine
            • May 2009
            • 53
            Before initialize ALL NVM, try to reset only four cells.
            Reset NVM location 762 - 315 to 0 for black.
            Similarity NVMs for CYAN 762- 314; MAGENTA 762-313; & YELLOW 762-312 and reboot copier.
            • newtech
              • Mar 2009
              • 13
              reply
              If I intialise it , and the toner catr is not full will I be able to see the difference immediately in the reading if it works?
              • copymachine
                • May 2009
                • 53
                Yes
                • newtech
                  • Mar 2009
                  • 13
                  reply
                  ok thks i will try it tomorrow
                  • newtech
                    • Mar 2009
                    • 13
                    reply
                    hi i have tried to nvm 762-315 but the m/c does not recognised this chain function
                    • copymachine
                      • May 2009
                      • 53
                      If u have PWS diagnostic, let's try use it. If no, u can attempt initialize all NVM. And third way, reload IOT firmware
                      • XeroxTechBrazil
                        • Aug 2008
                        • 199
                        PWS, EDOCs, IOT Software Available
                        Tools you need to service this machine (PWS, EDOC, and IOT software, are all available:
                        JorgeXcalak@live.com
                        • mubtuhogar
                          • May 2009
                          • 13
                          How do I those NVM resets? I want to reset a Workcentre M24 to factory default setting to see if it solves a touchpad problem. Can anyone help me?
                          W. Maldonado
                          • copytech200X
                            • 264
                            i feels that u mention dcc240 model is arita ?reset toner counter chain 752-686 -k,752-685-c,752-684-m and 752 -683-y all reset to zero.only apply to toner counter fail to monitor life span eg 25% ,75% empty ..good luck
