dc 700 and 250 toner compatible?
  • vvvit
    • Jun 2009
    • 11
    is toner for dc 250 and 700 compatible?
    according MSDS (P-7010) dc 700 and MSDS (P-7004) dc 250 toner look likes very close.
    maybe someone test toner for dc 700 on dc 250?
  • copymachine
    • May 2009
    • 53
    My customer use long time toner 700 for DC252 with no problem
    • victorr
      fiyuzer
      regard,much ask to report part.nomera on detail fiyuzeraxerox 242
      • vvvit
        • Jun 2009
        • 11
        write in russian, didn't undestand u
        • TechMate
          • Mar 2008
          • 285
          Originally posted by vvvit
          is toner for dc 250 and 700 compatible? according MSDS (P-7010) dc 700 and MSDS (P-7004) dc 250 toner look likes very close. maybe someone test toner for dc 700 on dc 250?
          Yes they are compatible and surely it would work. I've seen it on some of our clients but we don't recommend swapping toners. Long term effect - deve tank and IBT belt wear and tear
          • Caffeine
            • 391
            I suspect that the developer and belt would be okay actually, since the toners are (as I understand it) physically identical as far as particle size and whatnot. The known difference is that the 700 toner has a lower melting point. I don't think this along would probably cause problems, and may even allow better fusing on some heavier stocks.
            My concerns, though, would be if the color balance of the 700 toner and 250 toner are the same. The 250 'expects' its toner to be a certain color, and bases all of its color math on that. If the 700's toner is a slightly different shade, that could cause problems. Obviously the 700 itself would be expecting its own toner and be fine, but throwing it into a 250 could lead to some color calculations based on a (now) false baseline.
            The toner is definitely different, but that doesn't mean they changed the color formula of the toner. The 700 is the newest EA toner... 'EA-Eco' and the 250 is the 2nd gen EA toner, 'EA-HG'... The original EA toner, just called 'EA' was used in the 1632/2240/3535 and they DID change the magenta color formula from the EA to the EA-HG... Many of the sneakier sort do still use them interchangeably, despite that, but in discerning print environments, it MAY not be wise.
            You'll almost certainly be safe with the black, though!
            • WIWA
              • Mar 2009
              • 97
              No, no compatible 700 is a smaller particle to compensate the velocity, and melting point time. You may use 700 on 250 with this minor problem more developer cloud so you will contaminate laser units faster that is the only inconveniece. But if you use 250 on 700 you will get unfused copies on heavy material. By the way a small blend of 250 and dc12 works fine on a DC12.
              Hope this help,
              Wiwa 72
              Gonzalos build v.1.0
              • Caffeine
                • 391
                Ooh, good info. Thanks for the correction!
                Is there any benefit to mixing some DC250 toner into DC12 toner? The DC12 toner is already very cheap (cheaper than DC250, I think, no?) so I would wonder if there is another reason to do it?
                Along a similar line, there is a thread here about using 4110 toner on the 250 for black. I posted my experience and findings. Do you have any further info on that topic? Direct link to that thread: http://www.copytechnet.com/forums/xe...lor-260-a.html
                • WIWA
                  • Mar 2009
                  • 97
                  Well, I just do it on my personal DC12 and work like a charm the finish is more glossier basicly 3/4 dc12 1/4 carrera (same as olimpia). But be carefull on this I use my DC12 once in a while I don't know results at long runs but could be a good experiment.
                  Hope this help,
                  Wiwa 72
                  • Andrey_Russia
                    One of my friends tried 250 toner on 700 and said it won't work.
                    There were some ugly pictures in the end.
                    Any new tries?
