photomanual - how to change fuser roller in Xerox Ph. 7750
another 2 screws - and remove bar with 2 thermistors
taking away a clip from one side of roller
then gear, bushing and bearing
taking away a clip from another side
then bushing and bearing
removing old roller
the new one
and insert
i inserting roller, wrapped with protecting film, but it brings more problems than benefits - nex time i will insert roller without film
assembling parts in reverse order .
before installing lamps desirable to wipe it with alcohol
fuses on this plate replaced by polyfuses (or multifuses) - so "fuser chip" is disabled!
