Xerox 7132 Error code 092-310
  • Kenny
    • Jun 2009
    • 529
    HI,
    I have a problem with my photocopier/printer. It dispalyas the error code 092-310 and will not function. I believe this error to relate to the adc sensor but cannot find it!
    Can anyone help?
    Regards
    Kenny
  • pal.xerox
    7132 issue 092-310
    please see below procedure i hope it will help you.
    There is a failure in the ADC Sensor circuit.
    [IMG]pws://file/xerox/edoc/wc7132/icons/arrwup.gif[/IMG]Procedure
    Enter NVM Read Write location [752-007] and check the value.
    The value is within operating range. Yes No Unanswered
    Verify the condition of the circuit between the ADC Sensor and MCU PWB.
    The circuit is free of damage. Yes No Unanswered
    Repair the circuit as required.
    Check the operating voltages between the ADC Sensor and the MCU PWB.
    The voltages are correct. Yes No Unanswered
    Replace the MCU PWB ( PL 11.1).
    Replace the Sensor Bar Assembly ( PL 11.1).
    Originally posted by Kenny
    HI,
    Can anyone help?
    Regards
    Kenny
    • abdou
      • 39
      after inisialising NVM value, make copy in black mode and check quality, if the quality copy is not good donc you have a probleme with black developer housing causing by the brush was sparse on the magnetic roller. Subsequently, it was found that the screws holding the trimmer bar in place in these developer housings were rotated relative to their initial position.
      you can fixe the screws or change the developer housing
      there is a new part list for developer housing solve this probleme
      <FONT face="Arial Black">
      K: 604K42980 (Developer housing) 675K38910 (Developer Material)<SPAN style="FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-family: 'Times New Roman'; mso-fareast-language: EN-US; mso-bidi-font-weight: bold">
      • screwdriver08
        • Jul 2010
        • 160
        Where exactly is the ADC Sensor circuit and the MCU PWB? and how can I "Enter NVM Read Write location [752-007] and check the value.
        Repair the circuit as required" cause it keeps displaying 092-310 and wont let any of the buttons function.
        • hemanth1987in
          Re: Xerox 7132 Error code 092-310
          hi
          first you have to check the all developer contains, if any developer is low replace it.
          check ADC values in PRO-CON test.(if u have had any idea about ADC values here u can identify the problem by seeing these values)
          second clean ADC sensor bar.
          third check the patch on IBT,if it is not good clean IBT belt.
          Fourth check developer module caps. if it is not their replace it.(If it is not their tonner will not pump into the module)
          fifth cross check MCU.(some times if we replace MCU it will reset all NVM values)
          • JustManuals
            • Jan 2006
            • 9838
            Only 3.5 years too late....
