bill counter xerox m118 - c118
  • gano
    • May 2025
    *I have to reset my xerox m118's bill count, how can I do?
  • johnner66
    • Mar 2009
    • 265
    first you need to have a zeroz count m/c take the two ic from the iit pwb 24c16 n put it to the m/c you want to change then replace the ic you take out from the m/c one by one
    • gano
      does ic2prog work with eeprom?Otherwise wich programme should I use?
      • johnner66
        • Mar 2009
        • 265
        you dont need to programm just take the less count eprom put the m/c you going to reset n put the origin ic one by one
