appears these error codes 093-310 and 093-311 in the machine and I have no manual for this equipment. might help me get the look of a suggestion. already thanks
xerox workcentre 7132 wrong 093-311 and 093-310
Rotary housing banging noise, 093-310 fault codes and/or light areas / deletions.
Cause:
Bound up developer housing.
Remove and inspect each developer housing. The faulty housing was bound up because the door for the trickle broke loose. The developer will dump into the waste sump if the machine is run for an extended period with this door removed. Reinstall the loose part to it's location or replace Developer Housing -
