Pro 65 Cleaning system
  • vmx12
    • Sep 2007
    • 55
    having issues with a pro65. it appears that the cleaning system isn't able to keep up during longer runs. It gets a bad back round until reboot when the initial setup allows cleaning system to re clean everything. Any ideas?
  • Milo Wilson
    • 498
    WCP 65? Run xerographic setup using the PWS laptop and watch the numbers. You might need to change the developer if the machine has over 900,000 copies on it
    • xcopytech
      • Aug 2006
      • 1783
      replace developer, clean or replace donor roll and if xerographic module have more than 150.000 copies, replace it
      also suggest to clean ROS unit
