Workcentre Pro45 network controller problem
  • Kenny
    • Jun 2009
    • 538
    I currently have a Xerox Workcentre Pro 45 which has stopped printing from the network. The network controller still ping on the network but will nor connect to the copier. I have tried swapping the firewire cable at both the copier and network controller end in all possible configurations with no success other than the copier wouldn't startup and eventually requested a restart. Anyone have any idea what this could be caused by?
  • xcopytech
    • Aug 2006
    • 1794
    do you have any meesage on copier screen?
    • Kenny
      • Jun 2009
      • 538
      Only message displayed is 'Network Controller Unavialable'
      • xcopytech
        • Aug 2006
        • 1794
        Check Controller power supply, if do not work, replace it, do not try to replace glass fuse if it is blown.
        If power supply is ok, then check HDD, replace it and reload system software.
        BR
        • Kenny
          • Jun 2009
          • 538
          The power supply seems ok. The network controller lights are blinking and the unit can be pinged on the network.
          How would i reinstall the system software to a new hard drive??
          • xcopytech
            • Aug 2006
            • 1794
            must have xerox pws and system software for WC45 machine
            • Kenny
              • Jun 2009
              • 538
              Do you know where i could get a copy of these?
              • TzALbg
                • Dec 2007
                • 111
                Try to change first Fire Wire cable between NC and mashine after that try to change PCI Firewire PWB on SIP and in NC .
                If you have ping there is no problem with system software .
                Don't load system software version above your system software version should be 4.xxx.xxx.xxx or 3.xxx.xxx.xxx
                • Kenny
                  • Jun 2009
                  • 538
                  Thanks, Already tried to change the Firewire cards in the Network Controller and the Main machine body.Also tried a few different firewire cables in both of the ports of each firewire card
                  Thanks again
                  • TzALbg
                    • Dec 2007
                    • 111
                    Then try to reload system software but you have to use altboot method and you have to know the first number of SS version and you have to load the same
                    First try to open web page of mashine using internet browser
                    • Kenny
                      • Jun 2009
                      • 538
                      I will try to get in via a web browser. However i don't have a copy of the system software for this machine and to date have not had to perform a software reload on one. Do you know where i could find the system software and how easy is it to reinstall the NC.
                      Many thanks in advance
                      • XeroxTechBrazil
                        • Aug 2008
                        • 199
                        Loading Software - Private Message
                        You have a private message re: loading the IOT software.
                        • ac3243
                          • Oct 2009
                          • 24
                          Another WCP45 with corrupt HD
                          I have a WCP 45 with HD problems. I don't have the files to install the software to a new HD. Can I just clone a working 3.98.50 drive from a working WCP 35? Is there a better firmware to put on?
                          • tech9
                            • 216
                            hi , does it print a configuration report ?
                            • ac3243
                              • Oct 2009
                              • 24
                              Configuration report
                              The one with the HD problem does not print a configuration report. The one I can clone works great.
