A little help please!
  • Scotty C.E.
    • Aug 2025
    Not quite copier related, but I cannot get to the copier because the computer is telling me:
    Intel Boot Agent FE v4.1.10
    Intel Base-Code, PXE-2.1 (build 883)
    Copyright 1997-2002
    PXE-E61: Media test failure, check cable
    PXE-M0F: Exiting Intel Boot Agent
    1962: No operating system found. Press F1 to repeat boot sequence.
    Checked cable, unplugged cable, even tried to reload windows, blue screen is protecting system with a shut down.
    Has anyone out there ever encounter such a problem?
    Is the computer fried?
    Any response or help (if any) would be most appreciated.
    Thank you for your valuable time and being there.
    Sincerely,
    Scotty C.E.
  • bernyb
    • 42
    It says it can't find the operating system so you need to reload the operating system if you still have it.
    • Scotty C.E.
      Thanks bernyb!
      We did try the O.S. reload only to find the hard drive took a dive.
      With a new H.D. and a fresh Operating System install I'm told we'll be o.k.
      Scotty C.E.
      • JustManuals
        • Jan 2006
        • 9838
        But not just any hard drive. It must be a drive that is compatible to the copier. Of course you didn't mention what copier it is and my crystal ball is a little foggy today.
        Paul@justmanuals.com
        • Scotty C.E.
          Found out that it was'nt the hard drive afterall.
          The system would not boot because one of the sticks of memory failed.
          Scotty C.E.
          • bernyb
            • 42
            Aiyiyi!
