Xerox 242 Service Access Code
+ More Options
Posts
  • Naomi Lynn
    • Jul 2025
    Does anyone know the access code for a 242 Docucolour to reset faultcode 093-314
  • TechMate
    • Mar 2008
    • 285
    Reset NVM 762-312 to 0
    • Naomi Lynn
      How do we get to NVM 762-312 on the control panel to reset this
      • Naomi Lynn
        Please Please Help
        • TechMate
          • Mar 2008
          • 285
          go to service mode. hold down 0 (zero) for 5 secs, don't release then press start. enter password 6789 -confirm. press login/out button. press systems settings/systems settings/common settings/ maintenance diagnostics/nvm read write. enter the nvm value- read, change the value to 0 and save. then exit or close until the machine will reboot by itself (dont turn off the machine using power switch)
          • Naomi Lynn
            Thank you mate!
            This all worked atreat so far - cheers
            • Naomi Lynn
              Need help 242 Xerox Docucolour - error code 093-317
              I have this new error code 093-317 - is this related to another colour on the machine
              • xcopytech
                • Aug 2006
                • 1794
                black toner dispense fault
                • TribalBen
                  • Sep 2009
                  • 26
                  Will this work for the 240 as well?
                  • Fizzy
                    • 12
                    Re: Xerox 242 Service Access Code
                    Hello,
                    I can't access that menu! After I enter the password 6789, the screen goes back to "All Services". And at that stage I only have the option to "Stored Programming", "Language"and "Setup Menu".
                    Please help!
                    • bojans
                      • 1313
                      Just read carefully TechMate's post and you'll access the service mode!
                      • Fizzy
                        • 12
                        Thanks for your reply. I cannot access the Service Mode!!!!!!!!!!!
                        When I power on the printer, this is what I see on the screen:
                        http://tinyurl.com/kej55tk
                        On this screen the only options available to me are the following: "Stored Programming" "Language" "Setup Menu"
                        • bojans
                          • 1313
                          • Fizzy
                            • 12
                            HOW do I get to the "Service Mode"?
                            • livewire
                              • Sep 2011
                              • 608
                              You have error 093-317 = Dispensing Faults.
                              Enter the diagnosis, as colleague said and reset 762-315 to 0.
                              If you can not get into the diagnostics, perform GP1 Forced HDD Format.
                              Do you have the service manual? Codes to activate the software options? (If something goes wrong).
                              If GP1 you do not help, turn off the machine, disconnect the scanner cable between the ess and the scanner. Reboot the machine.
                              You'll get error 16-311. Ignore this error. Enter diagnostics and continue to troubleshoot the 093-317 problem.
                              Finally, turn off the machine and hang scanner cable.
                              Success!
