xerox DC3535 fault code 116-361
  • a.ghafari
    • Sep 2009
    • 46
    HI everybody
    I received fault code 116-361 in UI XEROX DC3535. relaoding software v1.1,v1.2 via PWS not usefull. changing HDD and reload s.w again but didnt work. is there any suggest to solve this . tanks all
  • davidj7
    • 1107
    clone hard disk
    a machine is only as good as your tech : source:screwtape ; the scary one
    • IronC
      • Oct 2008
      • 11
      How?
      What clone tool...
      • davidj7
        • 1107
        paragon hard disk manager
        • IronC
          • Oct 2008
          • 11
          Is it work with this tool?
          I try ghost,acronis...with no success !
          • xcopytech
            • Aug 2006
            • 1794
            Is not possible to clone HDD.
            HDD is empty, just have 6 partitions on it.
            Try with new HDD, which never have been used and formated, put in machine and perform HDD Initalization (4+stop+power save)
            • davidj7
              • 1107
              xcopytech: i did clone the hard disk with paragon and as acronis showed, paragon also showed it as empty .I tried to initialize the non working hard disk, it didnt work. then i did a clone of the working HDD using paragon and then did a HDD initialize and viola!!!! it worked. P.S The hard disk after installation is shown as empty.
              • xcopytech
                • Aug 2006
                • 1794
                which software you use for cloning?
                • IronC
                  • Oct 2008
                  • 11
                  Borisa ,
                  He use Paragon software
                  • davidj7
                    • 1107
                    xopytech: paragon hard disk manager
                    • IronC
                      • Oct 2008
                      • 11
                      Upload image
                      • copydan
                        • Aug 2011
                        • 13
                        Re: xerox DC3535 fault code 116-361
                        Hello everyone. Is there a disk image of this anywhere? My HDD failed and I cannot clone it onto a new HDD. Thanks in advance!
