Xerox 4150
  • snook123
    • Aug 2025
    Xerox 4150
    Lost the admin password is there any way to reset to default ie 1111
    Cheers
  • tech9
    • 216
    this can br done by entering diagnostics
    press and hold the # key then press the login/log out key
    the diagnostic login window will appear
    enter 1934 then touch enter.
    select dianostic routines
    then other routines
    select dc001 reset auditron master pin
    select reset auditron master pin
    select confirm.
    then exit diagnostics.
    • snook123
      Thanks i will give that a go.
      Cheers
