XEROX 635 FAX
  • tcanepa
    XEROX 635 FAX
    FAX SAYS REPLACE DRUM. DRUM REPLACED. USED ONLY XEROX DRUM, SUPPOSED TO RESET AUTOMATICALLY. STILL SAYS REPLACE DRUM?? ANY SUGGESTIONS...THANKS
  • ToshibaGuy
    • Jan 2005
    • 77
    Re:XEROX 635 FAX
    if it is a Workcenter Pro 635, it is a Toshiba TF631, I\'ll se what else I can dig up for you.
    • suckis
      • Dec 2006
      • 165
      When the Drum Unit requires replacement, the Fuser Cleaner and
      Ozone Filter must also be replaced. Do not replace the Drum Unit
      with one that has been used. The DRUM LIFE WARNING display
      does not clear if a used Drum Unit is installed.
      That's what the SM only says.
      ! RTFM !
      My site: http://www.e-club.gr/
      • toshibadale
        • Apr 2007
        • 117
        Turn unit off. Hold down the 1, 3, 0 buttons and turn unit on.
        display will say fc/mr hit the 0 button then start.
        Turn off and on.
        This will reset the drum.
