Slow network scanning on a Xerox 7345
  • sanpan
    • Jul 2025
    Hello,
    We have a Xerox 7345 setup to scan to a network folder on a shared drive using SMB. Everything works fine, but it takes forever to transfer the file to the folder. Is there a way to speed it up? The default template and memory are set up according to the attached images. Thanks!
  • jneezy2008
    Software/IT
    • Mar 2009
    • 72
    I'm not familiar with Xerox MFPs at all but I have had slow network scanning problems before. A couple things to try:
    1) Change the network speed(from 100Mbps to Auto or vice versa or change from Auto to 10Mbps, etc).
    2) Plug the Ethernet cable into a different port at the customers switch.
    What type of documents are you scanning? How many pages? Lots of pictures in these documents or primarily text?
    The snozberries taste like snozberries!!
    • adriansto
      • 2387
      http://www.copytechnet.com/forums/at...1&d=1254283769
      • jayc67
        Independent technician
        • Sep 2009
        • 100
        What kind of switch do you have?
        Is the solution of Adriansto working?
        • sanpan
          Thanks for the suggestions. I will try plugging it in to a different switch port and try adjusting the speed setting. The switch is an unmanaged Netgear 10-port switch. Thanks Adriansto for the documents, looks like this is not the first time this problem has come up. I will look into those possibilities once I return to the site.
