Background on DC2060
  • costou
    • Sep 2009
    • 44
    Hello,
    since yesterday, i have a yellow background in every prints.
    it's just in the part superior of the print, i changed the yellow developer, just the developper NOT the assembly, and i changed the print cartridge to be sure, and it happen again. I don't know what to clean or change.
    If anyone have an answer.....
    Thank you
  • jayc67
    Independent technician
    • Sep 2009
    • 100
    Originally posted by costou
    Hello,
    Thank you
    Can you scan a copy and send it on the forum?
    Do you change the corontron?
    • costou
      • Sep 2009
      • 44
      ok I send a copy of a scan (in A4 not in A3) but i don't know if we can see the problem in the scan......
      there is a background very clear in the part superior of the sheet. but just in the impresion area, not in all the sheet (without the mardge).
      so....thanks
      • costou
        • Sep 2009
        • 44
        and yes the corotron is changed cause I changed the print cartridge
        • davidj7
          • 1107
          interchange 1st btr in the ibt assembly with another color since you have changed all the other things that could cause the problem. and could u scan another print with some image or which clearly shows the problem.
          Have you cleaned the ROS for yellow
          • costou
            • Sep 2009
            • 44
            here's other print.
            we can see the difference between up and down, and the background yellow at the up of the sheet
            and sorry my english.....
            • davidj7
              • 1107
              more of yellow in the leading edge or inboard or outboard? (meaning which side came first)
              • costou
                • Sep 2009
                • 44
                the sheet is come out exactly like that, when you are in front of the printer, the sheet is like the scan, so the yellow is in the up, so I think it's the inboard
                • jayc67
                  • Sep 2009
                  • 100
                  try to reset the NVM value
                  • davidj7
                    • 1107
                    did u try exchanging the 1st btr roller?
                    • costou
                      • Sep 2009
                      • 44
                      hello,
                      I don't understand anything, but i interchanged between printcartridge yellow and magenta, and now, ther is no background.
                      i don't understand because at first, i had a background yellow so i changed the print cartridge with a new print for the yellow, and the background still printed. And when I interchanged with the magenta, ther is no problem......
                      if the problem comes again, i will say it to you.
                      Thank you all for your answers.
                      • davidj7
                        • 1107
                        now i am not able to figure out what happened...........well anyways machines working . good luck to you
