Xerox 245 problem
  • ccopy
    • Aug 2008
    • 51
    Xerox 245 problem
    We have a Xerox 245 that is ghosting images on the front & back. Before it was just ghosting on the bottom of the 2nd side which we eliminated by darkening the image quality but that is no longer working.
    It seems as tho the toner isn't being spread evenly throughout the developer module.
    Originally, we had the main copper gear in the back grind down to nothing. We replaced that and we had the same issue as above. We replaced the main motor and that corrected the ghosting the first time. We then had the main copper gear go bad again (which seems to be a common issue with this machine). We then replaced the developer module. That seemed to have fixed it for a while but the ghosting has reoccurred.
    Thank you in advance for any feedback or help.
  • TzALbg
    • Dec 2007
    • 111
    Check transfer/detack assembly for correct position of corotron wires in end blocks.
    • ccopy
      • Aug 2008
      • 51
      We checked that and it looks fine. Our problem is mostly on the bottom corner of the page where toner isn't being distributed evenly.
      Any other thoughts?
      • ccopy
        • Aug 2008
        • 51
        Here are some pics of what the coverage looks like.
        • tech9
          • 216
          I would try another dev tank and xerograhic module and do an all copier nvm initialistion.
          • Milo Wilson
            • 499
            What software level is the machine? There might be a spar listing for this type of defect.
            • xeroxsharp
              • Nov 2008
              • 270
              Any other thoughts?
              HI
              If I look at pics, could be xerografic problem (drum modul,tc/dc corotron,dev. housing,HVPS?)
              But first of all,try to clean laser unit inside-all the glasses.
              BR
              • ccopy
                • Aug 2008
                • 51
                Ok, we tried pretty much everything as suggested. It seems to be that its not getting enough toner, maybe from the bottle to the developer module.
                Any chance there could be a clog somewhere preventing the toner from getting to the unit? We already replaced the motor that turns the toner bottle.
                • tech9
                  • 216
                  change the whole dispenser unit not just the mot, and run the TC setup in diagnostics.
                  • ccopy
                    • Aug 2008
                    • 51
                    We just replaced the whole unit. It may have 20k copies on it, no more.
