DC12 poor image - pic attached
  • JimmyB
    • Jun 2008
    • 77
    i need advice. have a look:
    before a few days a did MAX setup on DC12 and after that, sometime dc12 print (make) a stain of printing image. (on pic background full is:cyan 60, yellow 20)
    this happened on all color in the same place, usualy on first few copy, after that on some pages.
    any suppose about that?
  • davidj7
    • 1107
    looks like you need to clean /replace carona wires and grid
    • gregoryk
      make a hard stop before paper passes throught fuser i think you have fuser problem
      • xcopytech
        • Aug 2006
        • 1794
        as davidj7 said, first check cc assy, also clean ptretransfer corona in drum cartridge.
        • tech_c3
          • 31
          try to test print internal pattern to isolate problem.
          if test print is with same problem, you have to concentrate
          on xerographic process either on drum, developer, ibt or fuser.
