Xerox 4150 Scanning
+ More Options
Posts
  • Tmoore
    Xerox 4150 Scanning
    Hello!
    I'm trying access jobs I've scanned to our Xerox 4150 networked copier. I've changed the default template, used the IP address of my computer (with port 139).
    When scanning the status shows the job process and then eventually deletes the job.
    Any suggestion is appreciated.
    Tony
  • ApeosMan
    • Nov 2009
    • 183
    It should show some sort of error code in the job history somewhere saying what the problem is. It could be incorrect login credentials, share/security permissions or incorrect destination host details.
    If you find the error code, then look it up in the manual or Xerox web site, then hopefully you an idea of what's wrong.
    • stangmanok
      • Mar 2010
      • 15
      Make sure you have a valid user acct for the 4150 to use on the computer you're scanning too.
