Xerox DC12 - Noise from deleloper
  • JimmyB
    • Jun 2008
    • 77
    Sometime my Xerox DC12 have noise like metal to metal friction, increasingly in time.
    i located, that noise coming from developer housing (in front OB section i think)
    Probably some gear or bearing are for change?
    Any suggestion or help will be appreciate
    thank you
  • bojans
    • 1313
    Hi JimmyB
    I had this problem when customer did lot of B/W copies and black developer housing got overfilled. If you have Eureka search for 9-363 code.
    • tonerspot
      • Nov 2008
      • 79
      провери лагерите на девелоперните кутии
      • rockin57rod
        • Mar 2008
        • 73
        It's probably time to put in the 655n131 developer bearing kit and the 655n132 developer gear kit. They have a life of about 250K.
        • a.ghafari
          • Sep 2009
          • 46
          Abnormal tone from DC 12
          some time it mybee from developer drive clutch in deve/ibt drive module.
          you can change or trim it.
          • rockin57rod
            • Mar 2008
            • 73
            That would be my second guess...the 121k14881
