Xerox WC Pro 35
  • gitana1983
    • Mar 2009
    • 141
    Xerox WC Pro 35
    Hi everybody,
    Im looking for help with a Xerox WC Pro 35, I have an error code 0956-00-00 and have not been able to find out what it means.
    Any help would be greatly appreciated, service manual, anything.
    Thanks in advance.
  • Milo Wilson
    • 508
    You need to double check the error code. That's not a valid error code listing.
    • gitana1983
      • Mar 2009
      • 141
      Now the machine does not show any error code, it turns on and when it tries to make the copies, after it scans it stops and says "Internal Power Failure"
      Any ideas what this might be? Fuser unit is new
      • tech9
        • 216
        Clean your transfer/detack assembly or replace them,also while your at it pull in and out your blue cleaner a few times this cleans your charged scorotron. If all fails you most probably got a faulty HVPS.
        But normally giving the the transfer wires a good wipe and dust of cures this fault.
        • gitana1983
          • Mar 2009
          • 141
          Thanks for your help, I will try this on Monday and let you know about the results.
          • hana_freak
            • Oct 2008
            • 44
            h**p://www.4shared.com/file/244759197/6c9f16e0/142724000.html
            • gitana1983
              • Mar 2009
              • 141
              THANKS
              Hi, Thanks for your interest, I was not able to fix the machine we are still pending on that one. I tried to open the file that you told me but it said it had some error and was not possible to do it, I will appreciate it if you can send it to me again or to my email gitana1983@hotmail.com.
              Thanks a lot in advance.
              • hana_freak
                • Oct 2008
                • 44
                ops my bad... try this link.. ther are some files that could be usefull
                4shared - free file sharing and storage - share folder - My 4shared
                • Assal3D
                  Re: Xerox WC Pro 35
                  dear sir ,
                  I've HVPS failure 9.060 ... My my chargers are all cleaned ... what should i do bro ?
                  Ahmed Assal
                  • tech9
                    • 216
                    Re: Xerox WC Pro 35
                    First i would replace the transfer and detack corotrons. If you still have the fault then replace your HVPS.
                    • SEnder
                      • Jun 2008
                      • 36
                      Re: Xerox WC Pro 35
                      I have this problem with LVPS. See if you have there blown resistor on LVPS board. Should be 200ohm.
                      • Guest
                        Re: Xerox WC Pro 35
                        Hello!
                        If scorotron replacement did not solve the problem then simply replace the drum cartridge!
