Xerox 7228 error 004-345
  • netranger
    • Aug 2009
    • 5
    hello together
    on by xerox 7228 s found an error (system)(004-345)
    does anyone know the errors?
    thank
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • adriansto
      • 2387
      Communication default between MCU and HVPS , 5 V is missing.
      Cyan drum cartridge fault. Replace cyan drum.
      or try this:
      There is +5 VDC from P/J574-5 to P/J574-4 on the HVPS Control PWB ?
      Disconnect P/J574
      There is +5 VDC from J574-5 to J574-4.
      There is +5 VDC from P/J406-B5 on the MCU PWB to GND
      Check for open circuit or loose connections in the 5VDC supply wires between P/J406, pins B5 and B6; and P/J574, pins 5 and 4.
      Check the wire from J406-B5 to J574-5 for a short circuit to GND. If the wire is OK, replace the HVPS Control PWB
      Switch off the power. Check these wires for an open or short circuit to GND:
      • <LI id=svc.imper.0000647840>HVPS Control PWB P/J574-9 to MCU PWB P/J406-B1.
        <LI id=svc.imper.0000647844>HVPS Control PWB P/J574-8 to MCU PWB P/J406-B2.
        <LI id=svc.imper.0000647848>HVPS Control PWB P/J574-7 to MCU PWB P/J406-B3
      • HVPS Control PWB P/J574-6 to MCU PWB P/J406-B4.
      If the problem continues, replace the MCU PWB ( PL 13.1). If this does not resolve the problem, replace the HVPS Control PWB ( PL 9.1).
      • jeanpaul
        • Mar 2009
        • 117
        Replace cyan drum & tell me if OK
        • netranger
          • Aug 2009
          • 5
          Hello together,
          Is working since i replace the drum.
          THANKS for you help
