wc 4150 pws diagnostic tools required
+ More Options
Posts
  • pal.xerox
    Hi All,
    i need pws diagnostic tools for wc4150 can any one help me ?
  • artphil
    • Aug 2008
    • 155
    Hi Pal.Xerox,
    I need this too!
    Would you be so kind to share it with me, if I find i i'll get you it too.
    Kind regards,
    Artphil
    • Milo Wilson
      • 502
      There are no "PWS" tools for this machine. All are onboard.
      1. Switch on the machine.
        When the machine is in the ready state, press and hold the # key, then press the Log In/Out key. The Diagnostic Login window will open.
        Enter the password (default is 1934). Touch the Enter button on the UI.
        NOTE:
        Press the C Key to clear an incorrect entry. Three incorrect entries will cause the entry screen to lock for three minutes.
      2. The Diagnostic Screen will be displayed.
      • artphil
        • Aug 2008
        • 155
        But what if the internal software is malfunctioning?
        Do you need to replace some hardware?
        Kind regards Artphil
          NOTE:
        • gregoryk
          1. Open Microsoft Internet Explorer. Enter the machines IP address.
          2. Enter the machines IP address. Press return. The CentreWare Internet Services window
          will open.
          3. Click on the Properties tab.
          4. In the Properties window, click on Maintenance, then Firmware Upgrade.
          5. Enter the customers username and password. The Firmware Upgrade window will open.
          6. In the Firmware Upgrade window, select Browse.
          7. Browse to the location of the firmware files. Select the correct firmware file.
          8. Select Install Software. The firmware file will now be transmitted to the machine. The
          machine will automatically initialize when the upgrade procedure is finished.
          9. Check that the machine has been successfully upgraded.
          • artphil
            • Aug 2008
            • 155
            But what if this doesn't work properly?
            will open.
