workcentre pro c2636 communications encountered problem
  • tower
    • Feb 2010
    • 28
    I turn on the printer and after a few minutes on the display I see this error encountered communications problem, reset system by turning power off, then on, using the white power switch.
  • xcopytech
    • Aug 2006
    • 1794
    first check CCM NVM PWB in controller.
    maybe do not have good contact.
    also check battery on CCM NVM PWB does it have 3V
    • tower
      • Feb 2010
      • 28
      the battery on CCM NVM PWB measure 3V, what can I check.
      Can you help me.
      thanks
      • xcopytech
        • Aug 2006
        • 1794
        about CCM can check does it have good contact.
        If still have same problem you will need xerox pws for wc 2636.
        You will need to check dc133 for correct values, also dc 105 and maybe even to reload system software to machine.
        • tower
          • Feb 2010
          • 28
          Where can I find pws for WC 2636
          • tower
            • Feb 2010
            • 28
            DC 12-50
            DC 2240, 1632, 3535, M24
            DC 250 (Fiery included)
            WC 32-40
            WF 8825-8830
            I found these, which I can use
            • xcopytech
              • Aug 2006
              • 1794
              no one
              • tower
                • Feb 2010
                • 28
                Can you help me find pws diagnostic tools for WorkCentre Pro C2636
