Xerox Phaser 5500 Fault code 18???
  • Iascopi
    • 21
    Hello you all,
    There is Fault code 18 after 250 to 350pages printed!!! I have had Turn off the printer - pause 15-20 min turning on and then the same ?? I had tried the procedure from the sevice manual :"The Temperature Sensor or Humidity Sensor has failed", and there was nothing wrong!???
    The enviornment in the room where the printer work is ok I thinะบ !??
    Somebody help with some idea ???!
  • gregoryk
    is the humidity of the paper in the acceptable range?sometimes paper with hight humidity can cause this problem otherwise i think you must replace the environment pwba
    • stangmanok
      • Mar 2010
      • 15
      Is this a jam code 18 - Paper size jam? Or is it an Engine Error 18?
