Xerox Dc12 Fault 4 Color Dots On Prints
  • Peter Montgomery
    • 52
    RE: Xerox Dc12 Fault 4 Color Dots On Prints
    This is a chat conversation on Facebook with Gustav Gonget and Peter Montgomery about the cause of 4 Color Dots On Prints on the Xerox DC12.
    I thought others might find it helpful so I posted it here.
    Gustav
    Hi Peter, just wondering if you got my message yesterday regarding Xerox DC12?
    10:36pm
    Peter
    Hi Gustav No where did you send it to
    10:37pm
    Gustav
    I sent it as a FB message
    10:39pm
    Peter
    I'm in so many groups and get constant messages so now I don't look at them if you wnat to send a message the best thing is to post it on my wall. I check it every day at least twice. any how whats up with your machine?
    10:41pm
    Peter
    Just found your message ill read it now
    10:41pm
    Here is the message Gus sent:
    Gustav Gonget March 3 at 7:14pm
    Hi Peter, I've benefited from your DC12 help in the past on the forums, thanks so much.
    Now I have an issue that is urgent to deal with that's why I'm going through FB, I hope this is OK with you.
    I'm getting CMYK dots, one after the other parallel to the direction of the paper movement. I've seen some call it the traffic-light effect and I'd ordered for repair kits for the developer housing gears & bearings but they haven't arrived and I've a big critical job to do that does not need these spots (I do have a new drum).
    Is there any other fix for this, even if it's temporary, to avoid the dev housings from marking the drum (I'm assuming that's what's happening)? Thanks in advance. Cheers, Gustav (GusG on the forums)
    Back to the Chat:
    Gustav
    Basically getting "traffic-light" effect of cmyk dots from a defect on the drum due to probable wear of dev housings, I've ordered repair kits that haven't yet come but was asking if there's any sort of temporary fix for that?
    OK, now you got it twice, sorry
    10:42pm
    Gustav
    I see you answering a lot of DC12 questions, are you also familiar with the DC2060?
    10:45pm
    Peter
    I don't think there's much you can do with the dev housing because it's usually the bearing that collapses and then the shaft wears out as well. Have you isolated the problem to a particular dev unit.
    10:46pm
    Gustav
    Not really but my tech suspects it's the yellow
    10:48pm
    Peter
    I'd check all of them to see if they are about to wear out too so you can prevent it happening again. If one is worn the others will likely follow
    I know the 2060 but I've never worked on one
    10:49pm
    Gustav
    Thanks, I guess I'll wait for the repair kits to arrive and suffer the dots in the meantime
    10:51pm
    Peter
    Its probably all you can do
    10:52pm
    Gustav
    Thanks again for your time, have a great day, or evening as I guess it must be in Oz now
    10:52pm
    Peter
    No worries mate.
    Yeah it's 10:53 pm
    10:53pm
    Peter
    Do you mind if I post this conversation on my blog and in my copytechnet group.
    Gustav
    That's fine by me
    10:53pm
    Peter
    Thanks mate. Talk soon
    Colour Copier Service http://www.colourcopierservice.com
    Connect with me on...
    Facebook http://www.facebook.com/video/video.php?v=1223670679806
    Twitter http://twitter.com/pete_montgomery
    YouTube http://www.youtube.com/watch?v=_oc2wp_6T6k
    Blog http://colourcopierservice.wordpress.com
