xerox doc 12 error code 9-363
  • ygeezzy
    • Aug 2009
    • 33
    When I start up my Xerox docucolor 12, it starts to go through the warm up and stops and shows error 9-363. How can I fix this? HELP PLZZZZZ
  • GusG
    • Jul 2008
    • 198
    I've had that several times, in my case it's usually a blown fuse on the Rotary PWB, change that and you are good to go if that's the case. It can also be that you've run too many B&W prints and you need to replace the black developer and change some NVMs if you intend to continue doing that. Those are the most likely causes in my opinion
    • jayc67
      Independent technician
      • Sep 2009
      • 100
      Did the copier make the error after the 5 mn warm up or directly after power up? Did it make a big noise? If yes check the 2nd BTR, the gear could be broken.
      • JimmyB
        • Jun 2008
        • 77
        9-363 Control Logic detected that the Rotary did not reach the Home position
