Xerox Drum Replacement 4118/M15
  • coolhand
    • Jun 2025
    Xerox 4118/M-15
    Have just installed a new drum in each. Thru user panel scroll thru to maintence to new drum : entered yes, both units are worse than before. None had the need drum light, but both had really bad copies. The new drum units had a image as if the cleaning blades were bad. Put the old drums back in each, and they work just fine. However the same faint print is still the same on each. Thus the reason behind changeing the drums in the first place. There is no code to go into, that is differant from the user. Any thing i missed.
  • qhubekela
    • Jul 2010
    • 28
    Probably dirty laser (ROS) window
    • bojans
      • 1313
      Also clean mirrors and scanning lamp.
