xerox pe 120i
  • certinproject
    technician
    • Sep 2008
    • 15
    xerox pe 120i
    everythink working fine, except even if I make copies, even printing, everythink is black. very black. dark black. when I pull out the cartdrige I see the drum covered with toner and inside the machine full of toner. I try with 4 cartdriges there is no problem with the cartrige I think maybe some problem with the high voltage. any clue to fix ? thanks in advance.
  • stangmanok
    • Mar 2010
    • 15
    The service manual directs you to check the following:
    a.
    Clean the high voltage contact terminals.
    b.
    Check the state of the connector between
    the main board and the HVPS.
    c.
    Replace the HVPS.
    d.
    Replace the laser unit.
    e. Replace the main board
    • certinproject
      technician
      • Sep 2008
      • 15
      thank's for your replay, the laser unit I think is ok because I have the same result at printing and copying. I have clean the machine and every connector so I believe that I have a problem with the mainboard or HPVS. my question is how can I found where is the problem, maybe if you have the service manual can you tell me what to check on the HVPS or to mainboard, or if you can send me the electric diagram to see the voltage check points on the boards - only if you have time. I realy apreciate your answer.Thanks
      • adriansto
        • 2388
        Pull down the right cover and on PWB you'll see the right values for voltages
        You don't have any charge on cartridge drum.
        • stangmanok
          • Mar 2010
          • 15
          I agree. My gut is you need a HVPS.
          • hana_freak
            • Oct 2008
            • 44
            look at the HVPS and find any damaged electrolytic capacitor.. poor contact also make the misfunction of HVPS try to ressoldering all components on HVPS.
