Xerox DC230 problem: network controller disabled
  • Enzo
    • Jul 2009
    • 413
    hi friends. unexpectedly when I have turned on the car it has appeared me this error: network controller disabled. I don't succeed anymore now in printing from the computer in what the controller of net it is disabled. how to do for rehabilitating it? thanks.
  • tech9
    • 216
    Sorry not quite clear on what you are actually saying ? I you have a network controller fault you will need to do and Altboot first the 230's use the hyperterminal where you have to type in the commands. If it has been converted back to a DC copier i.e hard drive removed ess pugged out, then you will have to reconnect these back. Hope this helps
    • Enzo
      • Jul 2009
      • 413
      the problem is not that to remove and reconnect the plug. I have already tried to do it but the same doesn't work! I believe is a problem of inside commands to the machine.
      • suckis
        • Dec 2006
        • 165
        Have you got an error code to show us?
        ! RTFM !
        My site: http://www.e-club.gr/
        • Enzo
          • Jul 2009
          • 413
          is not shown any error code! the message is shown only to me that the net controller is disabled
          • gregoryk
            pres key button then # and ten 1,1 this will direct you to the service menu check the errors and tell us what is the fault code
            • Enzo
              • Jul 2009
              • 413
              ok thanks. I hope can resolve me this problem
              • Enzo
                • Jul 2009
                • 413
                the codes of error are:
                N5-1 POST result not reported
                and
                N7-11 IOT-ESS communication failure
                • Silvio Ribeiro
                  • May 2008
                  • 34
                  If etive giving flaw in the network controller and print it should show a fault code, what is this code? You will probably have to reload the software from ESS, but for this you have to have a PWS.
                  • Enzo
                    • Jul 2009
                    • 413
                    the fault code is tihis: N7-11 IOT-ESS communication failure . however I have a pws. how can I reload the software?
                    • Silvio Ribeiro
                      • May 2008
                      • 34
                      Spend your email I sent you how to do this. Step to you later, because I'm going out now.
                      • cantus smetana
                        Hello,
                        I have similar problem with a xerox document centre 490ST (b&w) and PWS 9.2.Coild you help me?
                        Thank you.
                        • Silvio Ribeiro
                          • May 2008
                          • 34
                          Cantus, good afternoon
                          Firstly the model of your equipment is different from the equipment of the Enzo, but I'll take a look here then I'll tell you how.
