Phaser 8560 error code( drum Maint. kit ) problem?
  • axyun
    • Aug 2007
    • 1323
    Customer called with poor fill in /white streaking 1/2" wide up and down right side of page. Customer got this after changing oil roller maintenance kit. My first call on this series printer. When I plled out oil roller tray from right side of printer I noticed that the metal spring plate on the rigt side near handle was standing up as opposed to being underlip of tray as on other end of tray. I adjusted so under lip.
    Then ran the procedure that fills in jet spots that are blnk by choosing ink color and jet number that was blank on white stripe test sheet. Was improving and when I tried printing white stripe test sheet machine went into WIPER/MEDIA DRIVE FAULTS. error codes 08,007.41 + 08,045.43 + 08,035.42. When I checked thed Drum Maint. Kit(oil roller) it was up on right side and resistant to removal. I guess it was in cycle when error code occurred. Any help on correcting this problem is appreciated. Frank/ActionPhotocopy
  • gregoryk
    Drum Maintenance Camshaft
    Assembly probably cracked
    • axyun
      • Aug 2007
      • 1323
      Thanks Gregory. Could the Mk have damage cam if spring plate on front of MK was up instead of under lip? Frank
      • gregoryk
        Yes frank it can do that i've seen it two times
        • axyun
          • Aug 2007
          • 1323
          Thanks again Gregory. I'll post results here when call is completed. Frank
