Xerox DC432st Service Access Code
+ More Options
Posts
  • phollawat Chaimoonchuen
    • Dec 2007
    • 71
    I have Xerox DC432 ST. It,s show code 83B1-0008. Please...?
    Thankyou.
  • Silvio Ribeiro
    • May 2008
    • 34
    Problem:
    the customer tries to send fax. The Document Centre tries to send the fax. We can hear it ring it tries one time sees that receiving fax is busy prints out a non configuration sheet without even trying to redial as all machines do.
    See if that solves your problem. 'm Experiencing the problem, the cause and solution to the code 83b1.
    Cause: Standup used to hold the fax boards ( especially black cubical one) does not allow NCU Board to be seated fully into the connector.
    Solution: Reform the stand off or remove to allow good connection.
