workcentre pro c3545 help PLZ
  • rabib
    • 63
    communications encountered problem
    I turn on the printer and after a few minutes on the display I see this error encountered communications problem, reset system by turning power off, then on, using the white power switch.
  • copymachine
    • May 2009
    • 53
    .Communications Problem Encountered "Communications Problem Encountered" message is displayed on the UI. First the dots go across the screen (sometimes called "Dots of Death"). Sometimes you will get a configuration sheet.
    Cause:
    Controller was not assembled correctly from manufacturing.
    The Ribbon Cable (PL 14.2, Item 21) was not seated correctly to the IIT/CCM PWB. When I removed the ribbon cable from the IIT/CCM PWB, there was a pin bent on the board. I reformed the pin and assembled the machine and everything worked fine.
    • rabib
      • 63
      Thanks copymachine
      but whene I run wcps diagnostics navigator "problem NVR"
      is there the solution to reset the NVRAM ?
      • copymachine
        • May 2009
        • 53
        Will try. Maybe NVRAM corrupt.
        • rabib
          • 63
          Merci copymachine
          you cant to send me the software (nvram) or the service manual plz ?
          • adeyemi
            • 378
            There s a problem during installation that causes a failure.
            Try the following and if your CCM NVM chip is not bad, it should solve your problem:
            Procedure
            Enter dC133. Check the time and date. Enter the correct values.
            NOTE: The hour, minute, seconds, month and date must be 2 characters and the year
            must be 4 characters. You must also select the AM or PM radio button.
            Select Apply. The machine should resets.
            Enter dC105 and set the install phases to "Customer Set-up". Make sure all fields
            in dC105 screen have the correct configuration. Select Apply. Machine may not
            reset.
            Exit Diagnostics (Exiting Diagnostic Navigator) (Complete Closeout).
            Switch off the machine (the power cord may need to be unplugged or the GFI switch
            pressed.).
            Power up and enter diagnostics dC133 and check time & date (enter or change if
            missing or wrong with correct format as stated above). Select Apply. The machine
            will reset.
            Enter diagnostics as soon as "Ready to Scan" or the Install Wizard appears on the
            UI, go to dC131 and set System Management Service - 0119 to false. This will prevent
            the UI from auto upgrading.
            Exit Diagnostics (Complete Closeout).
            The Install Wizard will appear on the UI. After completing the wizard, the machine
            should reset and display ready.
            Diagnostic Navigator will lose communication. When the UI comes back up, approximately
            25 dots, enter diagnostics (Entering Diagnostic Navigator). Go to dC105, set the
            Install Phases to Complete. Also, complete all fields with correct configuration. Click on
            Apply.
            Machine will reset again and when it comes back up machine will be in diagnostics
            mode, launch Diagnostic Navigator and perform a complete closeout. Machine will display
            ready
            Enter dC105 and set the Install Phases to Complete. Also, verify or complete all fields with
            correct configuration. Select Apply. Machine will reset again and when it comes back up
            machine will be in diagnostics mode, launch Diagnostic Navigator (Entering Diagnostic Navigator)
            and perform a complete closeout. Machine will display ready.
            Dgtal
            • rabib
              • 63
              Thanks adeyemi under test !
              thank you adeyemi (^_*)
              • xootanup
                communications encountered problem WCP3545
                I have the same problem. I try what copymachine said but nothing unusual with the ribbon cable. Any suggestions?
                thanks in advance!
                • rabib
                  • 63
                  HI ALL
                  whene I run wcps diagnostics navigator this message desplay
                  • Milo Wilson
                    • 503
                    It looks like you need a serious software upgrade. The software level is an older version.
                    • rabib
                      • 63
                      thanks Milo Wilson
                      I have the software C0_01_04.511 but whene I was to upgrade this message desplay
                      thanks in advance!
                      • xcopytech
                        • Aug 2006
                        • 1794
                        do not have correct path
                        select only folder C0_01_04.511 and you will see version for upgrade.
                        • rabib
                          • 63
                          Originally posted by xcopytech
                          do not have correc[ATTACH=CONFIG]4108[/ATTACH]t path
                          Thanks xcopytech
                          but same problem
                          • xcopytech
                            • Aug 2006
                            • 1794
                            • rabib
                              • 63
                              Yes xcopytech but is decompressed in follder !
