Need hard drive with sys software for Fiery EX12
  • copierpro
    • Apr 2007
    • 270
    Got in a Doc 12 with an ex12 yesterday and the hard drive is gone. Looking for a used working pull.
  • artphil
    • Aug 2008
    • 155
    Hi Copierpro.
    What you need are the installation cd's for this machine.
    Just plug i a new harddrive and reinstall the FIERY software for the EX12
    Kind regards,
    Artphil
    • copierpro
      • Apr 2007
      • 270
      Well, that's correct but Xerox parts does not have them (they can't find them without a part number - it is an accessory and not a part, etc etc) so my best bet is to find a working pull. You know where I can find the op sys cd's?
      • davidj7
        • 1107
        if nothing else works out for you let me know i will send you a pulled hard disk from ex12
        • WIWA
          • Mar 2009
          • 97
          Well be carefull with those Fiery's as best I know the hard drive is married with the mother board so they a tricky to handle . I tried already to use a har drive prepeared and formated on another Fiery and don't work on mine. Try to revive your original drive and make an image of yours and try.
          Hope this help
          Wiwa 72
          Gonzos build v.1.0
          • davidj7
            • 1107
            i bed to differ wiwa. Unless there is any hardware difference a hdd working one fiery will work in another.
            • xcopytech
              • Aug 2006
              • 1792
              Any HDD will work, just cannot replace main board and HDD at same time.
              If need to replace HDD must have working main borad and if you need to replace main board must have working HDD.
              • danito0203
                Hello. i need also this HDD, how could we contact?
                • Milo Wilson
                  • 500
                  Find a good compatible hard drive online for cheap. Then reload the software from the disks. There is no security feature that will keep you from doing that. Easy peasy.
                  • JimmyB
                    • Jun 2008
                    • 77
                    change HD with any standart IDE (PATA) hard disk and preinstall system from instalation CDs (they are 3pcs). you can put in 40GB, 80GB or 160GB IDE hard drive.
                    you cant use HD from another fiery, because will get error: illegal licence or any else .....
                    if you dont have instalation cds, let me know.
                    • Goshe
                      • Jul 2009
                      • 118
                      I did clone once from one Xp12 hdd to another because I don't have installation cd and fiery is working fine.
                      • kermit
                        • Jun 2010
                        • 4
                        hi, i also need cd's for EX12. I have version 1.0 but it's old and very bad. 2.0 will be fine.
